Advice on my PC build?
Tweed
This is my PC build: http://pcpartpicker.com/p/BxzxLk . I'm trying to go for a Batman theme'd PC, and I plan on adding the NZXT Hue+. I'm having trouble deciding my case fans, whether to go appearance over function, LED over CFM/dbA. What's important for me is the noise, I want my PC to be as quiet as possible, but I want it to be presentable, so no poop brown noctua :( despite the fact that they are known to be the best! LEDs are a plus, I like the Thermaltake Riing Fans, but they don't have a good CFM, dbA, RPM ratio, but people that I've asked had no complaints.
So to sum it up, I need help looking for a case fan, 2 120mm fans for the bottom of my case as intake (Static Pressure), 2 140mm fans for my radiator (pull config.), and 1 120mm for the rear of my case as exhaust. My case is the InWin 805 Black, and I really want to stick to the Batman theme I have planned, while being quiet, and beautiful to look at.
if you want quiet fans, silent wings 2 are decent, though lower performance than the noctuas
btw did you check out the N450 from nzxt? that's what people call the dark knight case or something because apparently it reminds people of the bat mobile lol
as for your pc build
1) maybe an i5 over an i7, unless you're doing something else other than gaming
2) slightly overpriced motherboard, but i guess you're going with aesthetics here so... ok, though might i suggest z170 sabertooth or maximus formula instead?
3) insane storage, but thats up to you
4) all these but a gtx 970 `-` kinda expected more
5) slightly overkill psu wattage unless you wanna go dual gpu config (though i dont recommend dual gpu config unless you're already using the best gpu)
-sigh- feeling like I'm being too negative lately
well, as everyone else always says.. 390 is better than the 970.
Gaming - Ryzen 5800X3D | 64GB 3200mhz  MSI 6900 XT Mini-ITX SFF Build
Home Server (Unraid OS) - Ryzen 2700x | 48GB 3200mhz |  EVGA 1060 6GB | 6TB SSD Cache [3x2TB] 66TB HDD [11x6TB]
Yeah my friend has the NZXT N450. I liked the InWin 805 better. Yeah not really a gaming rig, mainly for video editing, graphic design, animations, etc. I was thinking of going 650w PSU, but people said to go 750w just in case if I ever want to upgrade. Yeah as of motherboard, I'm between Asus z170-A or the Maximus Hero VIII Hero, depends on the case fans if I go LED, then Maximus, if no LED, z170-A. As of storage was thinking of just getting the M.2 PCIe SSD, and if I need more storage, I'll get the 850 EVO when I need it. I'm trying to go under $2000.
Yeah I was considering the 390, but graphics card is on the back of my mind right now. I'm trying to focus on my case fans because I'm having so much trouble knowing what to get. I'm looking for something quiet, fits my dark batman color theme, and has good airflow (cfm).
with an asterisk `-` its not better in all situations
then maybe you should invest in the x99 platform instead
I already have an Intel core i7 6700k :/. I pretty much have all my parts except graphics, storage, motherboard, psu, and case fan.
yeah if its not for gaming you might want to go to the x99 with a 5820k processor, and step down the GPU, though you might want to stick with NVIDIA for CUDA cores.
remember to quote the person you're replying so they'll get a notification
if thats the case, did you check out the fan i mentioned? as well as the motherboards
The 950 PRO doesn't actually load OS / games significantly faster than the 850 EVO. I'd just use a 1 TB EVO or 2 500GB on RAID 0.
If you have a chunk of budget you might want to upgrade your display, unless you're already running what you want.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
I checked the motherboards, I'm Googling/YouTubing the fans you recommended.
Noctua has Black/Grey fans and also Black/Brown fans.
Computer Specs:
Yeah I know, but people have told me that they are LOUD. Like the Noctua Industrial
he's not gaming, its a working machine
so its fine to get the 950 pro if he needs the bandwidth and iops,
dont i dont recommend that he do raid 0, the cons outweigh the pros, unless he needs the bandwidth
and raid 0 will actually makes the boot time longer due to the need to initialize the array
The industrial ones shouldn't be louder since they're literally repaints of the normal NF-A14. The redux might be a different story though.
Computer Specs:
the industrial fans are the loud ones
Perhaps they're just louder because they're faster. Then you can just tone them down. Or are they structurally different?
Computer Specs:
http://noctua.at/en/nf-a14-industrialppc-2000-pwm/
http://noctua.at/en/nf-a14-pwm/
the minimum rotational speed is different, thats what matter
noctua fans are quite loud after they get past about 600~700rpm, you can hear the humming sound of the motor
thats why people who buy noctua fans run them at extremely low rpm, because they perform well even at low rpms, and noisy when they are spinning fast
First link is broken? 404.
Computer Specs:
So a low RPM doesn't really matter? As long as CFM (high) and dbA (low) are good?
fixed it
rpm is just a number, its the air flow that the fan produce that is important
noctua fans perform well at low rpm, and stay quiet at low rpm, thats why people buy them
silent wings on the otherhand can go to very high rpm and still stay relatively quiet, but the performance is not as good as noctua fans (though i dont know how people compare them, but thats what i heard)
i own both of them and i still prefer silent wings over noctua, because noctua is still noisy even with LNA (1200RPM) but the silent wings are quite silent even when running full speed
A better designed fan will move more air at less noise levels. If you're feeling crafty you could get the noctua fans and spray paint em :)
Otherwise the be quiet! fans have a great aesthetic imo.
Computer Specs:
Are the bequiet! Silent Wings 2 SP or AF fans? They seem pretty good. Are they the best of the best? I want something somewhat quiet, not dead silent, and the performance to be above average, and aesthetically pleasing (LEDs are a plus with cool effect).
120mm: https://pcpartpicker.com/part/be-quiet-case-fan-bl062
140mm: https://pcpartpicker.com/part/be-quiet-case-fan-bl063
Yeah I was told spray painting may mess up the "weight/balance" of the fans and I'm not willing to risk that lol :P.
