My CPU: Intel Core i7-6700K
My RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz (PC4-24000) C15 Memory Kit - Black (CMK16GX4M2B3000C15)
My Motherboard: Asus Z170-A
The motherboard specifications page says 4 x DIMM, Max. 64GB, DDR4 3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133(O.C.) MHz Non-ECC, Un-buffered Memory
Will everything work straight away out of the box or will I have to do something with XMP or something like that?
Thanks in advance.
CPU: Intel i7-6700k - GPU: EVGA GTX 1080 FTW - Motherboard: Asus Z170-A - RAM: Vengeance LPX DDR4 16GB 3000MHz - CPU Cooler: Corsair Hydro GTX H110i - PSU: EVGA SUPERNOVA 650W P2 - Case: NZXT H440 White/Black - OS: Windows 10 Home - Mouse: Logitech G502 - Keyboard: Corsair Strafe Cherry MX Red RGB
https://linustechtips.com/topic/587231-3000oc-help/
it will work out of the box, yes, but it wont run at 3000MHz
you need to enable XMP for it to run at that speed
https://linustechtips.com/topic/587231-3000oc-help/#findComment-7649953
How do I do that?
https://linustechtips.com/topic/587231-3000oc-help/#findComment-7649964
Just now, Zack Brown said:
How do I do that?
you go into UEFI and you click the setting that says XMP and you click the option that says 3000 somewhere
then save and reset and youre done
https://linustechtips.com/topic/587231-3000oc-help/#findComment-7649969
Just now, Moonzy said:
just enable XMP in bios
Ok thanks a lot ;)
https://linustechtips.com/topic/587231-3000oc-help/#findComment-7649970
https://linustechtips.com/topic/587231-3000oc-help/#findComment-7649976
