Best Silent Intake Fans
iTonyy
I'm currently looking to replace the stock fans on my C70 that I'm using for intake at the front.
I'm undecided between Corsair AF12 and Noctua SA-12
but I noticed there are 3 different versions of the SA-12 (uln,flx,pwm) does anyone know the main differences?
Or are there any other good and quiet 120mm fans you recommend
3770k, Asrock Extreme 4, 16GB Dominator Plat, AX760i, 250GB BX100, 1.5TB Seagate, Win 7 Home Prem
they are different speed controls/set speed
uln (ultra low noise, low rpm 700-500)
flz (flexibility, 1200 900 750 rpm)
pwm ( pulse width modulation)
Main rig: i7 4790k, Cooler H55, EVGA GTX 980, Corsair Obsidian 250D, ASRock H97M-ITX/ac, G.Skill 8GB, 500GB 840 EVO, 1TB WD Black
Server:  HP DL380 G5 8x 300GB 10k Sata drives, 2x e5460 32GB Ram
NAS: Synology DS213 with 2 2TB WD Red Drives
  • 2 weeks later...
I have both AF120's in both performance and quiet edition and either one is good.
"An Excellent Signature"
Definitely go for the Noctua NF-S12a. It's their newest version of the NF-S12b which has a much better performance and has a much much silent operation.
\[T]/ Praise the Sun!
Super Budget Gaming Build: Intel Pentium G1610, Gigabye GA-H61M-DS2 rev. 3, Kingston Value RAM 4GB CL9 1333MHz, Fractal Design Core 1000, Corsair VS 450, WD 1TB, Powercolor Radeon HD 7750 1GB/GDDR5, (Optional: Asus DRW-24B1ST).
 (Total: $340 USD)
I can only recommend the Noctua NF-S12B FLX fans. I have them and with the U.L.N.A. adapter you really cant hear them !
XEON 1230 v2 / AMD R9 280x / 8GB DDR3 / Adata XPG SX900 256GB SSD / Corsair 300R Side Window / Corsair CX500M / Corsair M65 Green
Get the Noctua fans, if you don't like the looks of them, you won't be able to see them because the drive cages would be blocking them! lol
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
jeez, I can bearly hear them at normal speeds lol.
