Options For Headphones
Go to solution Solved by Stardar1,
1 hour ago, Dackzy said:
they are bad, just buy some hyperX cloud.
You need to put a little more than "they are bad"
1 hour ago, ddbtkd456 said:
Do you have a link to either of those?
Cheaper G430s: http://pcpartpicker.com/part/logitech-headphones-981000536
G633: http://pcpartpicker.com/part/logitech-headphones-981000586
Currently I was thinking about getting
Headphones: Logitech G430 7.1 Channel Headset  ($72.96 @ Amazon)
however I was wondering if there were any purple ones or other teal colored headphones available on the market? Never used the high quality headphones before do they make a difference when gaming?
If you've previously won the build off please pm me so we can get something worked out.
https://linustechtips.com/topic/584275-options-for-headphones/
1. You can get those headphones much cheaper.
2. if color is something you care about, check out the G633s, they are programmable RGB. Pricey, but super high quality.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621047
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621056
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621171
Solitaire.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621606
Sound quality is bad compared to what you can get for the same money, like 99% of all headsets. Did I mention that all Logitech headsets are bad compared to what you can get for the same money.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621649
that sounds like fanboyism.
I just got a pair of G933s that sound AMAZING. You cannot generalize an entire brand like that.
Solitaire.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621652
NO you sir need to learn the difference between sound quality and signature.
Yes I can when I have heard headphones with the same sound SIGNATURE and their sound QUALITY was better than the logitech ones.
Logitech makes some of the more okay headsets, but still bad compared to headphones with the same signature. I have not heard a single pair of logitech headsets that was good for the price and I have heard them all.
I can also say that Razer is utter shit at making sound because that is a fact.
The only headsets I would never recommend are Hyperx Cloud, Hyperx Cloud core, Sennheiser game zero and Sennheiser game one. The Sennheiser headsets are only if you dont want a separate headphones and mic
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621682
I will agree with you on Razer, but i have used a pair of clouds and the G933s sound far superior. I would even say that the G930s sound better once you adjust the equalizer.
Solitaire.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621684
Thanks for this....color is an important thing as I want it to match my fiances build. Either white, purple, or teal. Really don't want white tho, shows everything to quickly.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621753
I dont think they sound that good and the g930 also cost more than the cloud. I had the g35 when they came out (the wired version of the g930) I thought they were good and all that, then I tried something better and cheaper I thought g35 was bad after and it went on like this and now well you can just see my signature.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621754
Yes you can, when all of logitechs headsets are no good.
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621794
Thank you!
https://linustechtips.com/topic/584275-options-for-headphones/#findComment-7621806
