On my corsair cx600m, the picture is what I have to work with. I need to connect this with my 2x6 pin GPU. Not sure what I should do. For some reason my 6+2 cable doesn't fit into the bottom slot? Maybe I'm reading the psu wrong and it's wrong cable type. Guess I'm not sure what should go where. Help anyone?
Thanks
https://linustechtips.com/topic/583227-gpu-power/
turn the cable around and plug it into the TOP port.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/583227-gpu-power/#findComment-7610530
12 minutes ago, STRMfrmXMN said:
Plug the cable the other end into the PSU. One end of the cable should be labeled "PSU"
I can do that but I still need a total of 2x6 pin for my GPU
https://linustechtips.com/topic/583227-gpu-power/#findComment-7610594
Also I can't find anywhere where I could get a male to 2x male splitter
https://linustechtips.com/topic/583227-gpu-power/#findComment-7610600
As we've said, turn it around and plug it in and you will have a 2+6 pin connector.
https://linustechtips.com/topic/583227-gpu-power/#findComment-7610611
16 minutes ago, Bliznipa said:
Yes but I need two 6-pin connections total for gpu and a 6+2 does not fit into the bottom slot
Something done goofed up then, because it's just an 8-pin connector. You shouldn't have any problems
The 6+2 is not the end you plug in, it's the straight 8-pin. If it doesn't work one way, flip it round and try again. They only go in one way.
https://linustechtips.com/topic/583227-gpu-power/#findComment-7610723
Oo ok I do not have a straight 8 pin so maybe I just need an 8 pin to 2x6 splitter??
https://linustechtips.com/topic/583227-gpu-power/#findComment-7610738
You misunderstand me. The modular cable that comes with the PSU should have two connectors on each end with eight pins total on each connector. The one with 6 pins and another two coming off to the side is what you plug into the graphics card. The other end is what you plug into the power supply. Depending on what make/model you have it may be a solid 8-pin connector on that end or it may be a 4+4 connector like on a CPU header. Anyway, that's what you have to plug into the PSU. Do that and you should be grand.
https://linustechtips.com/topic/583227-gpu-power/#findComment-7610749
Doesn't the PSU come with a cable that has 8 pins on one end, and possibly says PSU, and 6+2 on the other end that may say PCI-e (or even 6+2 splitting off to another 6 or 6+2)?
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/583227-gpu-power/#findComment-7610871
That's what I was thinking it should but no I don't believe it came with onE at all. That's why I'm so confused about this
That makes sense. Unfortunately I don't have first cableyou mentioned which would make life much easier. It didn't come with that
Wherecould I buy that cord ?? That picture is like exactly what I need
https://linustechtips.com/topic/583227-gpu-power/#findComment-7611167
