where to place fans
MiguelitoIV
Damn hope that power supply doesn't explode...
Here's a great video on where to place fans:
thaanks!
dont worry, already upgraded to a seasonic s12 ;)
Just now, MiguelitoIV said:
thaanks!
No problem and the seasonic s12 is a great little unit.
What CPU cooler and what GPU you have? If GPU is blower style, then lower side should be intake. And if CPU cooler is stock or downdraft, top should also be intake.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
thanks for the response
the cpu is a stock
while the gpu is an inno 3d gtx 960 herculez x2? (idk if thats a blower)
the cpu is a stock
GPU is open-air style. So you are good with lower being exhaust and top one being intake.
oh ok. thanks!
i got one more question, my case specs says that the fan sizes on side panel where 12mm, but I measured it and it shows 10-10.5 mm. Are there 10.5 mm fans?
thanks in advance
oh and can you explain why this setup?
oh ok. thanks!
thanks in advance
How did you measure it? Fan size is measured along the side, not from screw hole to screw hole. So it from corner, along side to another corner. You can measure with existing fan, like rear one.
yes from screw to screw, with a measuring tape, my rear one is most likely an 80mm
I'm not at home now to check it. But I'm pretty sure its still 120mm. There aren't any standard size between 92mm and 120mm fans. So common ones are 40mm, 60mm, 80mm, 92mm, 120mm, 140mm, 150mm (either with 120mm or 140mm holes), 200mm and 230mm.
okay thanks, my other question is that why do you suggest an exhaust below, and an intake above? thanks
Stock cooler on CPU pushes air down towards heatsink. So intake right above it will bring more cool air in. If you would have tower cooler, I would suggest having both as exhausts.
GPU cooler has two fans which both intake from below card and push air towards PCB/heatsink. Air will then exhaust towards sides, all of them. So you will have fan right above fins.
oooh okay. thanks! really appreciate it :)
