Separate power supply for gpu?
Go to solution Solved by Telebubbies,
2 minutes ago, TheAlmightyKraken said:
This is my first build inspired by linus' cheap server gaming rig. I basically have every thing I need but the psu i have in the server has literally no conventional connectors so could i use an external psu to power the gpu and if so does the power rating of the second psu matter i.e. will it destroy my card if its too high? as i've had a hard time finding a psu that is low power and has two 6 pin pcie power connectors.
Also the gpu is Gtx 660 ti.
Thanks
It will not destroy the card if the power is too high. Your PSU just won't reach its full potential..
Thanks
https://linustechtips.com/topic/582486-separate-power-supply-for-gpu/
Thanks
just buy one good PSU
if you cheap out on a PSU then you risk killing your whole PC
a good quality PSU that can power your whole system is not that expensive
Thanks
It's a very, very ghetto way of doing things. Austin did it because he didn't have a choice. I'd try to save up to get refurbrished CPU that's about 1000W or higher.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
The power isnt the problem its the connectors. ive got two psu's in the server at 1000W but because they're server cpus they have no connectors coming off them.
It's just how I see things, if the only options is to get 2 PSUs, he should do it. However, if he would be able to get a single PSU that is 2nd hand or refurbrished... I'd consider it.
Main PC:
Case: TT P3
HTPC:
The TDP of a 660 ti is about 300 watts something like this would work: http://www.newegg.com/Product/Product.aspx?Item=N82E16817438012&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Don't forget you will have to jump the connectors on the the psu to trick it into thinking that it is connected to the motherboard.
Thanks! I shan't
