Radeon HD 7950 Boost vs GTX 670
Solved by Coaxialgamer,
Just now, IsFyx said:
That was what I was thinking too. However this says the GTX is better for gaming. And if the difference is marginal I would like the 3GBs as a selling point for the other system. I'm saving up for a 980ti (or 1080ti if i can hold my breath long enough), so it would be kinda temporary anyway...
If the 7950 is indeed superior, I guess it is more a question of how noticeable it is?
NEVER use gpuboss for anything more than comparing raw specs. They are unreliable and/or biased.
It will generally beat the 670 , thanks to AMD supporting their older cards better . But this difference should only be of a couple frames.
