so recently moved into a new house, modem/router are situated in basement (currently living with fam due to unforeseen circumstances)
looking around the house i do not see any ethernet ports, just the micro-ethernet ports (not sure what they are actually called), i am assuming these are (were) only for phone use.
Am i stuck just using a wireless adapter for my pc....they don't cost much so it wouldn't be a big deal.
if  i do need a wireless adapter, which one would be worth getting?
2.4 and 5 ghz connections
speednet stats: 13 ping, 90~ mb down, 12~mb up
https://linustechtips.com/topic/580330-do-i-need-a-wireless-card/
3 minutes ago, KabuTheFox said:
The port is probably for RJ11.
I'd see if you could try a powerline adapter first, to see how it works. If it performs poorly then wireless would be the option. 802.11n or 802.11ac?
What router / access point do you have?
I mean, if those pots in the wall are hooked up you can buy a cheap-ass modem for full Ethernet speed.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Any PCI-E card. Do not get a simple dongle or adapter because they can fail easily. Personally, I'd get one of these https://www.scan.co.uk/products/edimax-ew-7822pic-ac1200-dual-band-pcie-wifi-network-card-1200mbps-80211a-b-g-n-ac-24-5ghz-dual-high
However you can spend as little as £10 if you know what card you need.
IT Manager working in the Education sector.
trying to figure out if its 802.11n or ac .... not really sure where to look for that info
forgot to mention i am in USA
though i imagine theres similar cards for similar prices
Erm yeah, I guess there is. Either way, you can go into any IT shop and buy one so it doesn't make a difference I suppose.
5 minutes ago, KabuTheFox said:
the archer 1750 or 1900 both look pretty good, i will probably end up grabbing the 1750. there seems to be minimal difference between them
It's also worth testing out a powerline adapter in your home. The performance and stability can vary greatly depending on the wiring if your house, but if it's good then it will give you a better result than wireless.
Here is an alright one: http://www.amazon.com/TRENDnet-Powerline-Adapter-Gigabit-TPL-408E2K/dp/B00I0MKIDO/ref=cm_cr_arp_d_product_top?ie=UTF8
Here's one that I have: http://www.amazon.com/TP-LINK-TL-PA8010P-KIT-Pass-through-Powerline/dp/B00Y3QPG1A/ref=sr_1_1?s=pc&ie=UTF8&qid=1460405415&sr=1-1&keywords=tplink+av1200 sadly the wiring of my house is shit.
If there is somewhere you could return them to if they don't work in your house, that would be great. Like a microcenter.
theres a staples and walmart i can check that are pretty close, will post update on it soon
