2 monitors side by side for a specific use?
Just buy the second monitor and connect it. Then set it as primary and the 4K one as secondary. All full-screen programs such as games will run in the new monitor and any windowed program you will be able to drag to either one. Most programs like Web browsers will/should open a fullscreen mode in the screen the windowed mode was located. That's how you can switch between fullscreen/windowed in, say, Netflix without the program hopping from screen to screen.
Edit:
- For 144Hz, you'll need Dual-Link DVI-D or Displayport cables and connectors
- You shouldn't, but if your monitors support it, I guess you can daisychain using DP. I'm not 100% sure 144Hz monitor will work right while being daisychained with a 60Hz monitor...
- Oh... In that case, disable the screen you're not using (and automatically make the other primary) by pressing Win+P
- Cool. It's a great display.
