help with DNS/nameservers
In a nutshell, "mywebsite.com" has to be registered with a nameserver for the .com top-level domain (TLD). The nameserver for the TLD will respond to queries for "*.mywebsite.com" by directing them to a subordinate nameserver listed in the database of .com domains. The software that does this is typically called "BIND", "Berkeley Internet Name Database" named after the University it was developed at, UC Berkeley.
So basically you have to do 2 things:
a) Register with a TLD registrar. There's a variety of vendors. A highly advertised one is "GoDaddy".
b) Set up a name server for your domain using BIND (or similar) with details applicable to your own domain. And typically at least one backup. You can either do this yourself or get a commercial service provider to do it for you.
BTW, 192.168.x.x are not publicly routable Internet addresses, so if your web server is on such an address, it will never be publicly accessible unless you have the ports forwarded to a machine that is publicly accessible.
