NZXT H440 problem
By
Redjo
in Power Supplies
in Power Supplies
Solved by Acquire,
That review is for the original H440. In 2015 nzxt updated the case to increase air flow significantly by making the gaps in the front and top of the case larger. You most likely have the updated model. I run a dual 980 Ti setup (non reference) in this case with no cooling problems.
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
1
play_circle_filled
Latest From ShortCircuit:
