This is my build currently. I had one planned out earlier in the year, but prices changed so I had to adjust it.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.99 @ B&H)
Motherboard: MSI H170A PC Mate ATX LGA1151 Motherboard  ($93.88 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($34.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($56.83 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.73 @ OutletPC)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  ($169.99 @ Newegg)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  ($79.99 @ Amazon)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($74.98 @ Newegg)
Case Fan: be quiet! Pure Wings 2 61.2 CFM 140mm  Fan  ($11.90 @ Newegg)
Total: $766.28
Generated by PCPartPicker 2016-04-03 20:52 EDT-0400
I would most likely upgrade the 380 to Polaris or Pascal in the fall.
https://linustechtips.com/topic/576354-thoughts-on-build/
I'm assuming this is a gaming build.
1) If I didn't need the features of the H170 chipset, I'd go for an H110 motherboard.
2) Go for an R9 390 to pair with the i5 6500.
Other than that, everything looks fine! :)
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540582
4 minutes ago, nick5530 said:
You could save a bit getting this motherboard
https://pcpartpicker.com/part/msi-motherboard-b150mprovd
go for a 120mm fan 4 pack if you want more fans
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200072
Otherwise maybe consider a sandisk SSD
or perhaps a less expensive case
and maybe a single 8gb stick of RAM, so that you can upgrade to 16gbs later on much easier.
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540584
What is the difference between the H170 and H110?
Also, the reason I am getting the R9 380 is because I am going upgrade in the fall.
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540589
Total: $766.28
Its ok but dont expect to max out all games. with this build and a GTX970 then you would be maxing out games!
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540599
Not a great deal. You can read up on the differences here.
https://www.pugetsystems.com/labs/articles/Z170-H170-H110-B170-Q150-Q170---What-is-the-Difference-635/
It really depends what your needs are and what the different boards have. I, for example, need a lot of USB ports so I tend to go with the higher H or Z series boards. I also take looks into consideration since I like cases with windows.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540609
13 minutes ago, nick5530 said:
Would it be better to just buy a 970/390?
If you're only gaming at 1080p 60hz, there's not much reason to get higher than a 4gb 380, maybe step up to a 380X if it's not much more
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540684
https://en.wikipedia.org/wiki/List_of_Intel_chipsets#LGA_1151
Bit more stuff.
What are you upgrading to in the fall? It's a waste of money, so I'd say buy what you need now.
Quote
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540706
Bit more stuff.
I have heard that Polaris and Pascal are going to be big improvements. Not sure how accurate that will be, but I thought I would wait and see.
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540735
Even if there are going to be big improvements, what's going to happen to the $170 that you spent on your GPU? And then you'll be spending even more money on another new GPU.
Unless you have an option to recycle the old part, I'd say don't buy. And who knows how much you'll get back by selling it then.
So get what you need now, or just wait for Polaris and Pascal to release, and then buy.
Quote
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540751
So get what you need now, or just wait for Polaris and Pascal, and buy then.
Okay. Any idea on the release date?
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540755
No idea. There are no announcements on release dates yet, but expect more information by mid 2016. Release dates could be anywhere in late 2016, but don't quote me on these. :P
Quote
https://linustechtips.com/topic/576354-thoughts-on-build/#findComment-7540767
