I'm having trouble deciding between the GTX 980TI Hybrid from EVGA ($690 US) and the R9 Fury X ($635 US). Right now I'm running at 1080p but I plan to upgrade with the card to 1440p or 4k. I only want one card so no SLI or Crossfire. Is 4k even worth it with a single one of either of these cards? If not, which seems better for single card 1440. Other considerations are power usage. I have a 500w power supply and am expecting to have to upgrade as well. Any help would be appreciated!
/AMD FX-6350 o/c to 4.4/Sapphire r9 270x 2GB/2x8GB HyperX Fury red/MSI 970 Gaming/EVGA 500B/NZXT S340/Corsair H100i V2/HyperX Fury 120GB SSD, Seagate Barracuda 1TB/
https://linustechtips.com/topic/575274-help-choosing-a-graphics-card/
looks like the 980 Ti does have better performance, but it is more expensive.
http://gpu.userbenchmark.com/Compare/Nvidia-GTX-980-Ti-vs-AMD-R9-Fury-X/3439vs3498
My computers as of 2017/03
My Old PC
Dell Vostro 260 $150 2010
CPU: i3-2120@3.3Ghz, GPU: Intel HD Graphics 2000, ATI Radeon X1300, RAM: 4GB Axevir Budget Series, SSD: 240GB Radeon R7, HDD: random 250GB and random 160 GB, CASE: Crap from Dell, OS: Windows 7 Enterprise
My Current PC
Custom Build $1200 2016
CPU: i5-6600k@3.6Ghz, GPU: Sapphire R9 Fury, RAM: 16GB Geil EVO X, SSD: 240GB Radeon R7, HDD: Hitachi 500GB, CASE: Deepcool Kendomen, OS: Windows 10 Professional 64-Bit
Laptop
ASUS F8S $1150 2008
CPU: Core 2 Duo T7500, GPU: ATI 2400 Mobility, RAM: 8GB Mushkins, SSHD: 1TB Seagate Hybrid Drive, OS: Windows 7 Ultimate N and Windows 10 Professional
HTPC
MSi Cubi $200 2016
CPU: Pentium 3805u@1.9Ghz, GPU: Intel HD, RAM: 4GB Crucial DDR3L, SSD: 120GB Radeon R7
Other Laptop
HP 2210b $400 2009
CPU: Core 2 Duo T8100@2.1Ghz, GPU: Intel GM965, RAM: 2GB Hynix, HDD: Hitachi 160GB, OS: Linux Mint 17.3 and Lubuntu
*All Prices in the Canadian Dollar
$500 for an R9 Nano is probably better value, and it's a great 1440p card- essentially a slightly underclocked Fury X that's designed to throttle down on its own boost clock (not as bad as it sounds). However, the 4GB of VRAM might not be ideal for higher-resolution textures and high-polygon objects in the future.I don't think there's a decent single-card solution for 4k yet, and you might be better off waiting for Pascal and Polaris if that's what you want.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
That's where I get stumped, trying to decide if the higher performance is enough to justify the higher price.
I say get the R9 Fury-X
My Old PC
My Current PC
Laptop
ASUS F8S $1150 2008
HTPC
MSi Cubi $200 2016
Other Laptop
HP 2210b $400 2009
I've been overlooking the Nano because I wanted something water cooled. Maybe I need to get over that and get the Nano. Does the Nano have higher or equal performance to the fury?
1 minute ago, Seminole said:
I'm fairly sure you could get 4k 60fps on either of those cards in most games, if you can afford 4k then go for it. Running 1080p might be a waste though to be honest, you would get so much FPS it would probably exceed your refresh rate by a lot.
I'm either going to 1440 or 4k when I get whatever card, just haven't decided which yet.
Well keep in mind 1440p and 4k are barely comparable. 4k has 4x as many pixels as 1080p. You could bridge the gap at a 2k monitor instead of 1440p so you have less of a major choice lol.
Don't forget 21:9 3440x 1440, they make very nice high refresh rate ones, a lot of people like and prefer them unless you are really a fan of the 16:9 standard :)
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
