ASUS Digi+ Power Control Off at 4.6Ghz or Higher?
Solved by Ben_Upde,
It changes because the power requirements for 4.6Ghz and beyond is higher than the optimized settings allow for. The choices for CPU power phase control are; Auto, Standard, Optimized, Extreme. If your setting is Auto then it will choose which setting range is appropriate for your overclock. If you set it manually to optimized, you may run into stability issues.
I honestly wouldn't worry about it. Just monitor temperatures regularly to ensure nothing is getting too hot.
Edit - the CPU power phase setting is a sub menu under the Digi+ Vrm menu in the A I Tweaker tab.
