This is my first personal build. I wanted something small and compact rather than a large tower.
Hardware:
Water Cooler: Corsair H100i v2
Power Supply: Corsair AX760W
RAM: Corsair Dominator Platinum 16GB DDR4
Processor: Intel i7 6700k (Overclocked to 4.5Ghz)
Graphics: EVGA GTX 980 Ti SC
Motherboard: ASUS Maximus VIII Gene
SSD: Samsung 950 Pro M.2
Case: Corsair Air 240
PCpartpicker: https://pcpartpicker.com/user/Garrzilla/saved/7VZhP6
Cable management
Finished build
The battlestation
Monitor: Acer XB270HU bprz 27" (144Hz, 1440p, G-SYNC)
Speakers: Klipsch ProMedia 2.1
Headset: Astro a50s
Keyboard: Razer Blackwidow
Mouse: Razer Naga 2016
Mousepad: Razer Goliathus Extended
https://linustechtips.com/topic/572082-first-build-micro-atx/
Can you guys stop making me wanna just throw out both my PCs so I can build a nice and smol itx or even matx with a small case?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/572082-first-build-micro-atx/#findComment-7498272
Dat Green dude
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/572082-first-build-micro-atx/#findComment-7498281
You wasted money buying Dominator Platinums.  Also, power supply is overkill even if you wanted to move to a SLI setup.
Like the case.  The two chamber design is great for upping space efficiency.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/572082-first-build-micro-atx/#findComment-7498930
How about well done for a first build mate....
https://linustechtips.com/topic/572082-first-build-micro-atx/#findComment-7500523
You buy dominator platinum for the look, not the price/performance. They are the best looking ram in existence, and people buy it because of that. Don't be too critical :D it's a powerful build.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/572082-first-build-micro-atx/#findComment-7503029
