INs and mic are for input only, the other outs are for specifc types of audio connection, line is the typical "audio cord"
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/571686-motherboard-audio/#findComment-7494877
7 minutes ago, JoshPC said:
I have a set of speakers (2) which use a 3.5mm jack to connect to devices. if I were to hook them up to the back of my motherboard what out of the 6 circles would I connect the audio jack into.
Theres
line-in
rs-out
line-out
cs-out
mic
ss-out
thanks
Whichever one is green usually.
https://linustechtips.com/topic/571686-motherboard-audio/#findComment-7494885
Green circle is for audio out to your headphones / speakers (stereo 2, 2.1)
Pink circle is for microphone
The other circles are for surround solutions 5.1, 7.1 etc.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/571686-motherboard-audio/#findComment-7496090
The green headphone one is just for 2 not 2.1 as it doesn't send three audio signals it sends two left and right. the reason why you can use it with 2.1 is because people usually send it into a cross over which sends the low frequencies but you could do that with all of them (except for CS). Thats why there is a CS out put for centre and sub.
The Dick of the audio page!
https://linustechtips.com/topic/571686-motherboard-audio/#findComment-7496224
I used it with 2.1 speakers.
https://linustechtips.com/topic/571686-motherboard-audio/#findComment-7496355
