USB Fan Effectivness
Travis23s
How well do those little usb cooling fans work? My laptop gets pretty hot
Do you mean something like a laptop dock-thing?
Like this?
Thermaltake-Massive-V20-Laptop-Cooling-P
 I think NCIX did a vid on this:
Other systems I've built:
The kind that sit under your laptop? I've had a few of them. Get the one that is applicable to your laptop size. They work well.
if it is making noise and rotates it works, but they aren't too efficient,
if you use your laptop for gaming/ watching movie itwill be hot cos the cooling isn't as good as it would be in a pc
34 minutes ago, ThinkWithPortals said:
LDo you mean something like a laptop dock-thing?
Like this?
  Hide contents
Yep.
They're okay. They at least keep your laptop from burning up your legs, and they make for nice hand warmers.
QUOTE when replying to others / Quality over Quantity in your posts / Avoid ambiguous topic titles
Desktop: "Shockwave" Core i7-5820K / GTX 970 SSC / ASUS X99 Deluxe / 16GB DDR4 / 120GB Samsung 850 EVO / 2TB WD Black Caviar
Laptop:  "Archippos"  Dell XPS 15:  Core i7-7700HQ  /  GTX 1050  /  16GB DDR4  /  512GB NVMe PCI-E SSD
6 hours ago, LeapFrogMasterRace said:
Cooling pads don't actually reduce cpu and gpu temps that much at all so if it isn't going to be on your lap I recommend this. http://www.amazon.com/LC05-Cooling-Auto-Temp-Detection-Compatible/dp/B00XKU47Y2/ref=pd_bxgy_147_img_2?ie=UTF8&refRID=1GFF5WS7V4TG3A2V366S
Not going to lie. That is pretty bad ass. Only took them forever to come up with that.
