9 minutes ago, Weakey said:
The cable itself is fine, the thing is my pc doesn't see it. It's working only after I unplug and plug in everything again a thousend times.
If it may be a problem with network card, tell me how to check it without an another one. I don't have any in my house.
I think you are missing drivers.
Download these to a USB drive and install them on your PC:
Windows 10
Windows 8/8.1
Windows 7
||| Drakon (Desktop Build) |||
|| CPU: 3800X || Cooler: Kraken X63 || Motherboard: B450 Aorus M || Memory: HyperX DDR4-3200MHz 16G ||
|| Storage: 512GB 970 Pro + 500GB 850 EVO + 250GB 850 EVO + 1TB HDD + 2TB HDD || Graphics Card: RX 5700 XT Red Devil || Case: Thermaltake Core V21 || PSU: XFX XTR 750W 80+Gold ||
2 minutes ago, chiwas said:
First, you should try to ping your network adapter. Run CMD > "ping 127.0.0.1" . Whats connected to the other end of cable?
All 4 packets were sent with 0% loss.
There is a wireless range extender that is connected via WiFi to a router
Windows 10
Windows 8/8.1
Windows 7
Didn't work
7 hours ago, Dawson Wehage said:
Sounds Like A Card Issue
But how to check it ;-;
Are you sure the cable isn't damaged? if it is a fault in the MoBo port, you could try the warranty or buy a card.
As in the device picks up the wifi and tethers it to your PC or the PC picks up wifi and sends it to the extender to be broadcast?
Perhaps it a problem at the other end(the device) such as low power, driver issue, or just crap quality?
Edited by Godlygamer23
Clean up.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
The range extender and the cable are working fine, i checked it with my laptop. And the MoBo is like 3 weeks old.
Clean up
Check the MoBo for damage or buy/borrow a rj-45 expansion card.
1 minute ago, Weakey said:
The range extender is working fine, i checked it with my laptop.
Driver issues related to the device? is it requires any.
                   _/ V\
    ______|   __/_/| |
Just now, Weakey said:
I don't have a week to wait until the card arrives.
As I said the range extender is fine.
The range extender may require drivers on the PC, those may have failed to install correctly on the problem PC but successfully on the laptop, wouldn't hurt to check.
You could call/email you board maker and trouble shoot with them, new doesn't mean perfect, or buy a $30 usb adapter if you just need to get wifi to the PC.
                   _/ V\
    ______|   __/_/| |
