What is wrong with my python?
Go to solution Solved by Glenwing,
(b² - 4ac) = (25 - 4•25) = -75, you're trying to take the square root of -75. You can't take the square root of a negative number, so you'll need a special case for that, which outputs "no solution" or something like that.
Can't figure this out and I need a quick answer... been looking at it for about 2 hours now haha so I thought it was time to post. It's part of a larger amount of code, but I narrowed the problem down to "math.sqrt()" so I made a short version and brought it here.. Why do I get a "math domain error" everytime i run this??
import math
a = 5
b = 5
c = 5
quad = (-b + math.sqrt(b**2 - 4*a*c))/(2*a)
print(quad)
any solutions?
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/569809-what-is-wrong-with-my-python/
  Hide contents
import math
a = 5
b = 5
c = 5
print(quad)
any solutions?
maybe try the ^ sign for powers?
nope. same error. Not sure if that works in python anyway.
Like I said, the problem is because of "math.sqrt()" as whenever I remove it, the code runs fine.
1 minute ago, NJHourigan said:
I've never used the math functions, so I don't know about that, but could it be to do with how a quadratic formula will give two answers and python doesn't know how to deal with that?
i was doing both answers seperately, I made a quick short program with only one(+) so I could show you what my problem is.
Try using a different means of evaluating B raised to the second. If needed square B as a fourth variable and use it
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
yes and you can also use the trick of raising the whole function to the power 0.5 :)
math.sqrt(2) = 2^0.5
Just now, Glenwing said:
Probably the term under the radical is coming out negative. You can't take the square root of a negative number, so you'll need a special case for that, which outputs "no solution".
Well B^2 = 25 and 4xAxC = 100 so its the sqrt of -75. I think we all over looked that
Just so you're not mislead, sqrt of a negative will involve the non-real number i which I don't think python.math is loaded with.
Try
a=5
b=9
c=3
                   _/ V\
    ______|   __/_/| |
yeah I was just putting in random numbers from user input  thinking anything would work. my mistake!
int a , b , c;
cin >> a >> b >> c;
int delta = b*b-4*a*c;
if(delta<0)
            cout << "No real solutions\n";
if(delta==0)
            cout << -b/(2*a) << '\n';
if(delta>1)
            cout << (-b+sqrt(delta))/(2*a) << '\n' << (-b-sqrt(delta))/(2*a) << '\n';
Or , in Python :
import math
a = int(input())
b = int(input())
c = int(input())
delta = b**2 -4*a*c
if delta < 0:
            print("No real solutions")
elif delta == 0:
            print(-b/(2*a))
else :
            print((-b+sqrt(delta))/(2*a))
            print((-b-sqrt(delta))/(2*a))
y
34 minutes ago, Nineshadow said:
import math
a = int(input())
b = int(input())
c = int(input())
delta = b**2 -4*a*c
if delta < 0:
elif delta == 0:
            print(-b/(2*a))
else :
for that matter just leave it since all roots of 0 are 0
if (delta <0):
   quad=( "no real sol")
else:
print(quad)
                   _/ V\
    ______|   __/_/| |
