RAM shows incorrect speed . HELP
Solved by DevilishBooster,
If I had a nickel for every thread I've read with this topic......
It's running at the correct speed. It is probably displaying 800 instead of 1600 because that is how this particular mobo reports it to the OS. I could be mistaken, but you don't have anything to worry about.
5
1
toxic_worper ·
7
1
voltigeurramon ·
Posted in Troubleshooting2 -
1
1
