Posted March 21, 2016 I have $60 and I want to get either a new PSU for some upgrade flexibility or an SSD because I have hard drives. So what should I get? i like linux Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 21, 2016 imo get a boot ssd for windows and maybe some games with long loading times like bf4 http://www.amazon.com/OCZ-Storage-Solutions-Internal-TRN150-25SAT3-240G/dp/B01B4NUKMY/ref=sr_1_1?ie=UTF8&qid=1458520671&sr=8-1&keywords=trion+150 Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/#findComment-7467436 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 21, 2016 7 minutes ago, ShadowTechXTS said: I have $60 and I want to get either a new PSU for some upgrade flexibility or an SSD because I have hard drives. So what should I get? If you want to upgrade that GPU past (or possibly even to, if OCing) a GTX 960 or R9 380, then you'll need to upgrade the PSU eventually, but I would recommend an SSD. Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/#findComment-7467445 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 21, 2016 ok do I know my suggestion was flawed on your last topic, but SSD all the way on this one. No reason to get a PSU if the one you have is already working. SSD would provide an excellent speed boost. So much so you may be happy with the performance for quite a while and not need to upgrade (negating the need for a PSU) You'll get no performance benefit from a PSU, you will from an SSD.. No brainer really. Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/#findComment-7467448 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 21, 2016 That psu does not have a very good rep, but since your system is not very power hungry, it should be ok. with $60 you should be able to get a decent 120gb ssd, and a fresh install of windows on that baby will speed the whole OS up... Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz PSU: RM650x + Braided cables | Case: painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS) Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/#findComment-7467476 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 21, 2016 The PSU is in the range of "meh" (not excellent, but not a ticking time bomb either). Since your components are low powered, that PSU should be fine for a long whiled unless you wanted a new GPU as well. I recommend the SSD upgrade. My eyes see the past… My camera lens sees the present… Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/#findComment-7467503 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 21, 2016 40 minutes ago, ShadowTechXTS said: I have $60 and I want to get either a new PSU for some upgrade flexibility or an SSD because I have hard drives. So what should I get? For your system your PSU is fine so get the SSD you want man. My account is almost entirely dormant. Hope you all are having a grand time. Many years of fun were had here. Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/#findComment-7467561 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 21, 2016 SSD definitely Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/#findComment-7467565 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 21, 2016 44 minutes ago, ShadowTechXTS said: I have $60 and I want to get either a new PSU for some upgrade flexibility or an SSD because I have hard drives. So what should I get? Why is this even a question? This is like buying gas when you don't even own a car. Link to comment https://linustechtips.com/topic/568875-ssd-or-power-supply/#findComment-7467575 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
