Hi,
I'm thinking about upgrading to Skylake, if I'll do this I will get:
  • ASUS Maximus VIII Formula
  • Corsair Dominator Platinum 3000MHz 16GB (4x4)
  • Intel Core i7-6700K  4 GHz
Currently, I have:
  • Maxiumus VII Formula
  • Corsair Vengeance Pro Series 16Gb 2400MHz (8x2)
  • Intel Core i5-4670K Quad-Core 3.4 GHZ
I'm wondering what kind of performance increase I can expect.
Any thoughts on this?
"To the wise, life is a problem; to the fool, a solution" (Marcus Aurelius)
https://linustechtips.com/topic/567572-skylake-improvements-over-current/
Single thread performance-wise almost none in games.
The only thing that's gonna benefit you is HT in some games, but that's it... not really worth it imo.
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
19 minutes ago, Zandvliet said:
Hi,
Currently, I have:
gaming wise, not much performance gains
cpu horsepower is raised though because you're going from an i5 to an i7
though if you do get skylake, dont get 4x4gb ram, get 2x8gb and leave 2 slot open for future expansion...
-sigh- feeling like I'm being too negative lately
1 hour ago, Zandvliet said:
Hi,
Currently, I have:
just upgrade to the 4790K the difference between skylake and haswell is negligible http://cpuboss.com/cpus/Intel-Core-i7-6700K-vs-Intel-Core-i7-4790K
the only benefit is DDR4
skylake single thread performance is actually significantly better than haswell
he should notice quite a few fps increase in games, even if they dont use 8 threads
Well my info is based on anandtech's skylake review http://www.anandtech.com/show/9483/intel-skylake-review-6700k-6600k-ddr4-ddr3-ipc-6th-generation
This tells a bit of a different story...
cpu horsepower is raiser though because you're going from an i5 to an i7
Thanks! But could you explain more why not 4x4? And what you mean by future expansion?
well the motherboard only comes with 4 ram slots, if you fill all 4 now you cant add more later
but if you think 16gb will be enough for you until the end of this build (16gb should be able to last you awhile for gaming), sure, just get 4x4
Ah alright got it, yeah I won't be upgrading to more than 16GB so 4x4 will be fine for me.
Though I assume 4x4 is better than 2x8?
not for skylake, since they'll run in dual channel bandwidth anyway
Thanks, then I'll go with 2x8. Plus it's also like 50 euros cheaper, if I upgrade..
29 minutes ago, Zandvliet said:
Hi,
Currently, I have:
Just IPC. A 6700k averages better in performance than a 4790k, but in gaming, only increases FPS 10-20
GTX 1070 - Ryzen 5 3600x - Corsair H100i V2 - 32GB DDR4 3200
Check out my Minecraft channel here!
