Display without iGPU
Go to solution Solved by ShadowCaptain,
1 hour ago, ArkTheYO said:
@ShadowCaptain Thanks a lot mahn! So i have come to a conclusion after some reading and information that i gained through you that the motherboards these days dont have onboard graphocs and i require to BUY a CPU with iGPU or a CPU(Without an iGPU) and a discrete graphic card in order to get the display running! Hope this conclusion is correct? Thanks in advance!
Correct
4 minutes ago, ArkTheYO said:
Hey people,
I have a question actually! Is it necessary to have a discrete graphic card or is it to okay to have a CPU but without an iGPU(or a gpu in it) in order to get display.
If the CPU has no integrated graphics, and you dont have a graphics card, then you cannot connect a display
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453221
Do you have to have a iGPU event if you want to display just text?
Quiet Whirl | CPU: AMD Ryzen 7 3700X Cooler: Noctua NH-D15 Mobo: MSI B450 TOMAHAWK MAX RAM: HyperX Fury RGB 32GB (2x16GB) DDR4 3200 Mhz Graphics card: MSI GeForce 3080 GAMING Z TRIO PSU: Corsair RMx Series RM750x Case: Be quiet! Pure Base 600
Buffed HPHP ProBook 430 G4 | CPU: Intel Core i3-7100U RAM: 4GB DDR4 2133Mhz GPU: Intel HD 620 SSD: Some 128GB M.2 SATA
Retired:
Melting plastic | Lenovo IdeaPad Z580 | CPU: Intel Core i7-3630QM RAM: 8GB DDR3 GPU: nVidia GeForce GTX 640M HDD: Western Digital 1TB
The Roaring Beast | CPU: Intel Core i5 4690 (BCLK @ 104MHz = 4,05GHz) Cooler: Akasa X3 Motherboard: Gigabyte GA-Z97-D3H RAM: Kingston 16GB DDR3 (2x8GB) Graphics card: Gigabyte GTX 970 4GB (Core: +130MHz, Mem: +230MHz) SSHD: Seagate 1TB SSD: Samsung 850 Evo 500GB HHD: WD Red 4TB PSU: Fractal Design Essence 500W Case: Zalman Z11 Plus
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453233
@ShadowCaptain But what about having a motherboard with Onboard Graphics? Wpuld that help?
Yes, there has to be some sort of graphics chip, either part of the CPU, an APU, on the board, or a dedicated GPU
if you have no iGPU (and no dedi GPU) there will be no monitor connection on the motherboard at all
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453248
15 minutes ago, ArkTheYO said:
@ShadowCaptain So basically if get a motherboard which has onboard gpu(some sort of a HDMI connection) and a cpu without integrated GPU , that should  work right? , soory i am just a real newbie, so please help! Thanks a lot in advance :)
modern motherboards do not have a GPU on board, the ports are there for the integrated graphics chip built into AMD/Intel CPUs
Why are you buying a CPU without an iGPU, all modern intel CPUs (consumer grade pentiums, i3,i5,i7) have iGPUs built in, and they are useful  to have anyway as you can use intel quicksync for many tasks such as OBS recording etc
(xeons/x99 and some speciality chips like the P chips do not have iGPU but 90% do)
or you can use the intel iGPU (or amd) to run a PC without requiring a dedicated card
Curious why you are asking?
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453280
Why are you buying a CPU without an iGPU, all modern intel CPUs have iGPUs built in, and they are useful  to have anyway as you can use intel quicksync for many tasks such as OBS recording etc
Not true X99 doesn´t in fact all enthusiast platforms don´t from intel, only consumer grade CPUs do have an iGPU.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453288
sorry I should have clarified, correct Xeons, X99 etc do not, i will add that to my post to avoid confusion
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453302
Just now, ArkTheYO said:
@ShadowCaptain Thanks a lot first! This question into my mind whn i saw this video of Jayz2cents where he said that AMD's FX-8350 doesnt have integreated graphics so we require a discrete graphic card in order to run the display!
Correct, FX CPUs do not have a iGPU, and are not an APU so you require a dedicated graphics card to get ANY display
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453314
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453345
Correct
https://linustechtips.com/topic/567449-display-without-igpu/#findComment-7453556
