Difference between EVGA GEFORCE GTX 970 FTW+ vs. SSC?
Quelux
I am looking for an explanation of the difference between the EVGA GEFORCE GTX 970 FTW+ edition and SSC edition. Both feature ACX 2.0+. Also, I would like a suggestion of which would be better for use and possible overclocking in tandem with an Intel 6600k CPU and a ASUS Z170 Pro Gaming motherboard. Thank you.
FTW has a better cooler and a higher clock speed. If you have the money I'd just get the FTW, especially if you want to OC (since it's a higher binned GPU and the cooler is better, meaning it'll OC better)
A Guide For Getting Started With Linux
My first rig:   CPU: AMD Athlon X4 860k Cooler: Cooler Master Hyper T4 MoBo: Gigabyte GA-F2A88XM-DH3 Video Card: EVGA GTX 750 Ti Superclocked RAM: 8GB Kingston HyperX Fury White 1866MHz Storage: WD Blue 1TB PSU: EVGA 100-W1-0500-KR Case: Rosewill SRM-01
