Hiya guys :),
I would be really grateful if someone would help me with my problem, and the problem is that Ive got Razer Molten Naga for few years already.
Few days ago while I was on my laptop the my mouse started to lagg heavily and its sensitivity was fked up. After 3 minutes of lagging it stopped moving at all even though it was still glowing and i could still left and right click normally, but the cursor wouldnt move at all. The next day I plugged it in and it worked normally for around 5 minutes and after that it just started to do the same thing and then the cursor didnt respond at all. basically same thing today. I asked razer support for help but they did nothing. I checked to update any driver and tried uninstalling razer synapsis. nothing worked. In control panel it says the mouse is working fine, but its not!
I would be massively thankful for any kind of help and suggestions c:
https://linustechtips.com/topic/566034-razer-molten-naga-problem/
have you tried it on other PCs?
Just now, Anarchy Rose said:
nah man i did not :/
try it on another machine
if it still does the thing then your mouse is broken and you need to buy a new one
this time dont buy any razer crap, get a good quality mouse that will last decades
  • 3 months later...
Perhaps this could help.
I found it recently when searching for a fix for my Razer Naga 2014 which was having mousewheel jumping. Only managed a partial fix, need super glue
Dubs are better than subs
