Just put together my first NAS, planning to run FreeNAS. Completely new to this so any feedback is appreciated, thanks in advance!
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  (£52.96 @ Amazon UK)
Motherboard: Gigabyte GA-H81M-S2H Micro ATX LGA1150 Motherboard  (£37.98 @ Amazon UK)
Memory: Kingston HyperX FURY 8GB (1 x 8GB) DDR3-1600 Memory  (£26.98 @ Ebuyer)
Storage: Western Digital Red 3TB 3.5" 5400RPM Internal Hard Drive  (£90.84 @ Amazon UK)
Case: Fractal Design Node 804 MicroATX Mid Tower Case  (£79.98 @ Ebuyer)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£57.99 @ Amazon UK)
Wired Network Adapter: Intel EXPI9301CTBLK 10/100/1000 Mbps PCI-Express x1 Network Adapter  (£26.25 @ Amazon UK)
Total: £555.39
Generated by PCPartPicker 2016-03-15 19:04 GMT+0000
https://linustechtips.com/topic/566033-first-nas-feeback-appreciated/
6 minutes ago, leonard_sun said:
You might want to switch the HDDs to Black instead of Red.
What? Reds are meant for mass network storage.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
2 minutes ago, Groundedbeef said:
If you can afford it go red pro, you cant go wrong with a 5 year warranty. well theoretically, shit does happen, but then you do have the 5 year warranty to wipe yourself with :)
They're like double the price, so that's something I'll have to pass on. Though is it worth picking up a 128gb SSD for caching with freeNAS, if that's even a thing?
I've re-read the FreeNas Recommendations and RED is the best one for this case. But for the warranty you have a point there it's only 3 years for RED as compared to Black.
I dont know, i have have never done it myself, but id like to know so i will be lurking... in case someone answers.
Could buy another set of reds in 3 years time worse comes to worse and it would still work out cheaper than having failed red pros 5 years down the line.
That's a good looking first build - the extra nic card is kinda redundant though? Unless FreeNAS doesn't recognise the built in NIC chipset on the board.
If you want to do nic teaming, you might want to look more at second hand 4 port intel cards on eBay.
You probably won't notice much difference with SSD caching with brand new drives - especially over Gigabit. With FreeNAS you can add an SSD cache at a later time though, so you don't necessarily need to get it now.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
Oh I left that nic in accidentally from when I was looking at an 18 quid board that I read had issues with freenas. Thanks for the spot :)
I think I'll pass on an SSD then, rather not spend that additional £50.
Your RAM will act as the initial cache and it'll catch majority if not all traffic over a gigabit connection. Definitely a nice build. Some caveats:
It's strongly recommended by the FreeNAS community to use ECC ram, you'd have to switch out your motherboard and ram to achieve this. The H81 chipset does not support ECC ram. Likelihood of data corruption and bitrot is somewhat low, but still a risk. Something to consider.
If you're doing more than a single parity drive, the processor might be the choking point. I was using a comparatively under powered CPU - G1610 - and my 2 parity array maxed out at 81mbytes per second, upgraded to an E3-1220 and getting 256mbytes per second. (Bought it used off of Amazon, working great). I think the Pentium processor you chose the G3258 shouldn't have any issues.
If I could do it over again, I would've bought the E3 right off the bat, and did a Raid 10 instead of RaidZ1. I probably would've been happy if I bought the pentium processor vs the celeron.. just went cheap not thinking the processor would be a bottleneck.
Current FreeNAS:
Xeon E3-1220
Motherboard: SUPERMICRO MBD-X9SCL-F-O
32gb ECC unbuffered (Mushkin)
Case: RSV-L4411 (Not rack friendly, wasted 1U on a shelf...)
IBM m1015 flashed to IT mode
4x 3TB WD reds, RaidZ2
5x 4TB Seashit ST4000DM000 (Dead drive < 2 months) RaidZ1
