power supply clarification
Go to solution Solved by STRMfrmXMN,
11 hours ago, ShadowCaptain said:
That is the only difference, its $10, if you can afford $10 just go for it
EDIT: sorry RMx , im being dumb and thinking of the old RM, the RMx features japanese caps, they removed link because its kinda pointless on a PSU,
so really its the better model to get
Rifle bearing fan and lack of Corsair link on the RMx.
EDIT: I could do to quote the right guy xD @burningfyra
And yes, worth the $10 for the longevity of the fan but not for Corsair link unless you really need to read the voltages and wattage readout of your system.
Well i Rmx has full Jap Caps but a cheaper fan ... i have RMX850 and loving it apart from something it vibration/humming in my build which make my silent build not so silent.
Magical Pineapples
