GTX 780 Ti users forced to upgrade for "Ready" VR?
dfg666
Is that for the Steam VR test? If so, I would take any results with a pinch (or a handful) of salt. I've seen R9 280s marked as "ready" and 390s marked as "capable".
My system is marked as "capable" with SLI Titan Blacks, so I don't think the test is particularly reliable.
290X is a much better piece of hardware. Drivers were holding it back 2 years ago. That is no longer the case.
dont forget theres no actual real way to test what they are claiming as vr ready cuz its not a thing yet its more of a suggestion
According to steam and the comments, it seems sli is not testing right, or to be more precise, it fucks up.
Im running a GTX 780 Ti and it passed the RIFT combatibility test , currently getting a second GTX 780 ti
haven't run the steam vr test yet as im installing watercooling on it.
I wouldnt trust the VR test at all
It is a synthetic benchmark after all. In the case that some of you guys are insistent on spending hundreds, if not thousands, of dollars on VR equipment, I'm sure it wouldn't be too much trouble to put some money to the side in case you need to upgrade after testing an actual VR title.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
At default, it doesn't use more than 1 GPU. If you use the -multigpu launch command, it puts load on multiple cards, but the scores don't change at all. Who knows what the load on the second GPU is. It just seems to be artificial load from what I can tell.
This 100%, it doesnt mean anything at all, you can probably just lower your settings and run VR just fine even on an older PC
Unless the "test" PREVENTS you from running VR, all it is, is a number generator for epeen
Synthetics barely tell jack shit about what a GPU can do, really. Thats why I personally skip any Firestrike, Heaven, basically synthetic benchmarks (even from games themselves like Tomb Raider 2013 or GTA:V) in pretty much every benchmark video posted. I usually find a really taxing part of the game and benchmark it myself to see how much is being pushed/pulled in terms of power.
I'm pretty sure those are sequenced live timed based benchmarks aka hybrid benchmarks. They still can give an accurate result in overall performance especially GTA V's Jet and City cutscene due to stressing out CPU drawcalls.
