No, hyperthreading is far less efficient than having physical cores.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
No. 8 physical will perform much better.
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
Yes it speeds it up
no its not the same as full 8 cores
but why does that matter? all intel i7 or xeon CPUs have hyperthreading, you never get "just" 8 cores
I'm going to beat a dead horse here, but no, 8 physical cores are better. Hyperthreading only creates virtual cores, or additional threads, to aid the original physical cores, so the benefits to hyperthreading are not nearly as great as the benefits of more physical cores actually doing the work.
Hyperthreading is more efficient than 8 physical cores, but it is not more powerful.
if you have to insist you think for yourself, i'm not going to believe you.
I know. but i realy should have asked this
does transcoding/exporting video use the control units or the cpu register allot or is it simple 100% ALU
if its only alu then hyper threading would work big time?
or am i totay confused here
I'm still not quite sure of exactly what you're trying to figure out, but in this case HT vs non HT would yield up to about a 25% performance increase(maybe better in current CPU's).
Transcoding should benefit greatly from hyperthreading, as it can take advantage of splitting up tasks to different virtual cores(or whatever the correct terminology would be)
Although what he said is true. Physical cores are always better than logical ones. You got to consider that (In a modern CPU) one physical core means two logical ones, but it would still be splitting up the tasks in the same core. More (physical) cores means more logical hyper-threaded cores.
But i think what you're asking is "Should i hyperthread when rendering?" then yes. You should.
Peace.
But a ht core has stuff missing
so lets say CORE1 IS DOING STUFF, so HT1 picks up the rest of it or even other stuff
now if HT1 finishes the task before core1, it still has to wait on core 1 to finish before doing other stuff,
in this case Hyper threading would slow down performance
my question is confusing, but this is what im trying to ask
does video processing stuff use the Control Unit of a core, or is it all just number crunching so nothing would get slowed down?
In the case you presented, without hyperthreading the "CORE1" would do all the work by itself.  That's one of the points of hyperthreading, it dishes out the tasks more efficiently to make it so any "wait" would be minimized.
I think the confusion might stem from single vs multithreaded capabilities. Video editing/encoding/trascoding etc. can take advantage of multithreading in the way of parallel execution(simultaneous calculations).
Single threading / single threaded applications only process one command at a time, so hyperthreading doesn't offer any benefit.
Again I'm not sure about your question of the control unit, but in a multithreaded application you should always get better performance via hyperthreading.
unless the hyper threaded core finishes things before the original core, things may slow down
it will speed up from the compiling point
