Posted February 29, 2016 hi everyone! can you tell me what the best 1440p monitor is for gaming with a gtx 980 ti gpu? thanks! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 Go for an ultrawide, pref a 34" from LG. It don't have to be G-sync or whatever. Unless you of course play FPS games. ROG X570-F Strix | AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO ROG Strix XG349C | Corsair 4000 | Bose C5 | ROG Swift PG279Q Logitech G810 Orion | Sennheiser HD 518 | Logitech 502 Hero Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 (edited) Author 1 minute ago, Lethal Seraph said: Go for an ultrawide, pref a 34" from LG suggestions on what monitor from LG? p.s this is my 100th post (yay!) Edited February 29, 2016 by jol159 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 Acer Predator XB271HU or Asus ROG PG279Q "Well, not even last night's storm could wake you. I heard them say we've reached Morrowind, I'm sure they'll let us go." Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 Author 1 minute ago, MalaCraft said: Acer Predator XB271HU or Asus ROG PG279Q I find the predator a bit too expensive, might be just me Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 7 minutes ago, jol159 said: I find the predator a bit too expensive, might be just me it is cheaper than the asus unit and you did not gave us any budget limit "Well, not even last night's storm could wake you. I heard them say we've reached Morrowind, I'm sure they'll let us go." Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 Author 4 minutes ago, MalaCraft said: it is cheaper than the asus unit and you did not gave us any budget limit ok well lets say maximum £800 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 Author (try to be as cheap as possible) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 5 minutes ago, jol159 said: (try to be as cheap as possible) you can go cheaper if you choose a tn panel. depends on what specs you want. "Well, not even last night's storm could wake you. I heard them say we've reached Morrowind, I'm sure they'll let us go." Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 Author Just now, MalaCraft said: you can go cheaper if you choose a tn panel. depends on what specs you want. ok here are the specs I would want: 1. it can be any brand 2. hopefully Gsync, but if you can find a 1440p monitor for less that doesn't have Gsync I will take it 3. at least 60hz 4. hdmi or DisplayPort compatible 5. a response time less than or equal to 5ms and an input lag less than 10ms (hopefully) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 3 minutes ago, jol159 said: ok here are the specs I would want: 1. it can be any brand 2. hopefully Gsync, but if you can find a 1440p monitor for less that doesn't have Gsync I will take it 3. at least 60hz 4. hdmi or DisplayPort compatible 5. a response time less than or equal to 5ms and an input lag less than 10ms (hopefully) i dont know if there are any 60hz gsync 1440p monitors. the ones i know of with gsync are 144hz/165hz Take a look at these two Dell S2716DG Asus ROG PG278Q "Well, not even last night's storm could wake you. I heard them say we've reached Morrowind, I'm sure they'll let us go." Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 Author Just now, MalaCraft said: i dont know if there are any 60hz gsync 1440p monitors. the ones i know of with gsync are 144hz/165hz Dell S2716DG Asus ROG PG278Q that is why I said at least 60hz Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 1 hour ago, jol159 said: ok well lets say maximum £800 https://www.overclockers.co.uk/acer-predator-xb271hu-27-2560x1440-ips-g-sync-165hz-gaming-widescreen-led-monitor-black-red-mo-098-ac.html Far under your budget MSI Z97M Gaming | i7-4790k | NZXT Kraken X61 | 16GB Kingston Savage DDR3 2400 EVGA GTX1080 Ti FTW3 | EVGA G2 750 | Phanteks Enthoo Evolv | 1TB 850 Evo | 2TB 860 Evo | 22TB DS918+ Scarlett 2i2 | WooAudio WA7 Fireflies | Fostex TR-X00 | Beyer DT990 | MrSpeaker Alpha Dog | V-Moda M-100 | JBL LSR305 MK2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 29, 2016 Author 39 minutes ago, sobe said: https://www.overclockers.co.uk/acer-predator-xb271hu-27-2560x1440-ips-g-sync-165hz-gaming-widescreen-led-monitor-black-red-mo-098-ac.html Far under your budget well I wouldn't say it is far under my budget and I have chosen a monitor now (sorry about that) but thanks anyway if you are wondering what I chose it is the Dell S2716DG 1440p monitor Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 1, 2016 Hands down Acer Preditor XB271HU. 1440p 165hz and IPS. Plus it dosent have the light bleed issues Asus panels have been having. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 1, 2016 Author 8 hours ago, foamygopher said: Hands down Acer Preditor XB271HU. 1440p 165hz and IPS. Plus it dosent have the light bleed issues Asus panels have been having. ok thanks Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
