While that system is cheap, it would probably not make a good pfsense box. It's an old server. You can probably get the same performance from a quad core embedded cpu. Unless you dont care about the HUGE waste of energy that is used to power it, dont buy it.
My native language is C++
https://linustechtips.com/topic/555980-system-to-run-pfsense/#findComment-7325771
I would try sites like www.mitxpc.com or www.logicsupply.com, they offer a wide variety of hardware (including rackmount) that are non-proprietary. Granted, not as cheap as using spare hardware that is lying around, but definitely worth the price for small form-factor rack mount hardware.
I actually have purchased some 1U rackmount equipment to install pfSense for some clients, worked out great.
https://linustechtips.com/topic/555980-system-to-run-pfsense/#findComment-7326197
This is, IMO, the best way to run PFSense: http://www.pcengines.ch/apu.htm
Cheap, and very power efficient. Its also passively cooled and small, so you don't have to find a place to put it and worry about noise.
This is a pre-configured version of PFSense so you just install it on the mSATA drive and you are good to go: https://www.yawarra.com.au/support/operating-system-images/rident-software/
https://linustechtips.com/topic/555980-system-to-run-pfsense/#findComment-7326454
