Led strips?
Go to solution Solved by shadowbyte,
bitfenix alchemy
nzxt hue+
bitfenix alchemy
nzxt hue+
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/555018-led-strips/#findComment-7315013
HUE+ is in high demand and sold out everywhere. If you decide this is what you want I would highly recommend you sign up for email notification directly from NZXT. They will email you when they are in stock and you will have probably 8-10 hours to buy before they sell out again.
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
https://linustechtips.com/topic/555018-led-strips/#findComment-7315022
5 minutes ago, Oishter said:
I'm currently looking into slightly modding my h440. I want to add some white LEDs to the inside. I might want to light some exterior parts with green LEDs. Any suggestions on reputable LEDs?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007581&IsNodeId=1&Description=led%20strip&name=Case%20Accessories&isdeptsrh=1
There are ones that can do multiple colors. That would be a good choice.
https://linustechtips.com/topic/555018-led-strips/#findComment-7315026
If your wanting a predone solution Addoncustoms and Cable Mods both have great LED kits which can be run outside of the case for say underglow. In general you don't want to directly see the LED's themselves since the are very harsh but have it cast light out or off of surfaces to give it that nice even glow.
https://linustechtips.com/topic/555018-led-strips/#findComment-7315486
