- Project ProdiGOD -
M-ITX -> M-ATX conversion.
As you might be able to tell by the silly name already, i'm currently in the process of converting a Bitfenix Prodigy from ITX to M-ATX. This build will probably feature a ASUS Maximus V Gene and an EVGA GTX 680. I will upload my 3D model design later this day. Hope some of you might find this interesting! Pictures and build-log coming up!
*** I want to point of that I am totally aware about the Bitfenix Prodigy M, but i simply dont like the internal layout ***
Links to pictures:
The Design
Cutting has begun!
Disassembling the Prodigy
Going away for a week
I'm Back!
Fitting the PSU
Ready 4 paint
Paint and assembly
The Final Update
* Guys, any feedback would be awesome, as this is my very first true case mod. (Other than a sidepanel window on a Fractal Arc Midi) *
Hope some of you will find this interesting and maybe inspire you to do the same!  ;)
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/55291-project-prodigod/
You could always buy a Prodigy M if you wanted.
https://linustechtips.com/topic/55291-project-prodigod/#findComment-743269
I hate to be the one to break it to you but there is a prodigy m coming out that is the same size as a prodigy and is matx
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/55291-project-prodigod/#findComment-743270
I am totally aware that there is a Bitfenix Prodigy M coming but to be honest, i dont like the fact that the motherboard is upsidedown, and the PSU is located at the front. :)
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-743273
I think the prodigy looks good as is. It would be better if the rad support up top was better but I guess something like a h80i would be fine in a build that could go in one of these.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/55291-project-prodigod/#findComment-743400
#5  I also like the looks of the case as it is. That's why i'm not chaning the look of it, only the inside to support a M-ATX motherboard.
The reason of doing this is to maybe do SLI, but still stay in the "small" form factor of this case.
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-743587
@Butterfish, You may want to take a look at this. Honestly, in my opinion, this is probably the best way to turn the prodigy into an m-atx. http://www.overclock.net/t/1313366/complete-project-prodigious-ocns-march-2013-motm. Although it might take a fair bit of modding.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/55291-project-prodigod/#findComment-743839
#7 Yep, that's kinda what i'm aiming for ;) Not the looks but the internal layout. I wish Bitfenix would make the Prodigy M this way, rather than the upsidedown motherboard, the front PSU and the fact that the motherboard is located on the wrong side than normal.
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-746000
Here we go!
First stage: The design.
So, this is just my dream setup for this machine and is kinda overkill, but looks badass  :D This is not going to be the components i will use.
I did this model in SketchUp.
Them large pictures!  :o  :o  :o
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-746122
Cutting has begun!
I'm currently working on the motherboard tray and converting it from ATX to M-ATX. I took this tray from an old pc, so it spared me some money.
The blue lines indicate where i need to cut it.  :P
Pictures taken with my HTC One black edition - Thx Linus  :D
One tool to rule them all
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-750980
Small update!
First i would like to say thanks for the feedback and the everyone who is following!
I am working on making a good workbench to make cutting and modding easier. It's going to take i while, and we a getting it done by a professional in 14 days.  :unsure:  I will still try and do the work anyways, but it's gonna be at a slow pace, considering i don't have the proper tools and workspace.
Please let me know if you would like to see pictures of minor progress more frequently, or a major progress more rarely/unoften.
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-755248
Sooooo pumped about this! Can't wait to see whats next :D Small picture updates are always good too!
i5 3570k - MSI Z77 GD65 - 16GB Corsair Vengeance - Galaxy GTX 780 - Corsair AX650 - Custom CPU Loop - Corsair 650D - OCZ Agility 4 128GB - WD Black 640GB
https://linustechtips.com/topic/55291-project-prodigod/#findComment-758066
more cutting!
I decided to make a template with the dimensions of a motherboard, just to have a visual guideline.
Tray is almost done! Just a little more cutting and it's time to sand her down
The metal plate with the lines is going to be the backpanel of the case, where the motherboard tray will be connected to.  ;)
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-761373
final cut done  :D (for the mb tray atleast)
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-761655
The prodigod is properly not going to feature the maximus v gene anyway, so i'm currently looking for a z87 m-atx motherboard for this build. What do you guys think?
Gigabyte Sniper M5 (black and green)
Maximus VI Gene (red and black)
Asus gryphon z87 (military theme)
I'm open for more suggestions  :D
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-765599
cool, subbed
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/55291-project-prodigod/#findComment-765734
Thx for the comments! I've been looking at the sniper, and it's a pretty cool board. I am also leaning towards the Gryphon, since it would damn sweet with a gtx 780 reference and a h100i. Not that it''s going to have a effect of my choice but the TUF logo also matches the bitfenix logo at the front  :D
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-766392
Also, right now im running blue led in my case, along with blue in my keyboard and mouse. There is a lot to change if i go green ;)
Oh and the Gigabyte G1 Sniper M5 requires 5 slots on the motherboard tray if you want to do SLI and i only have 4!  :unsure:
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-766484
It's been a while since i last uploaded some pictures. I will hopefully do it later this day.
Now, the case can only hold 4 pci-e slots so no gigabyte m5 sadly  :unsure:
It's all down to the Gryphon z87 and the maximus vi gene.
Should i pay the extra for the audio solution? And what benefits do i get with the maximus over the gryphon?
I like the look of them both, but the gryphon fits the build a little better without the red and black.
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-769968
UPDATE
It's been a while since my last picture update, but some schoolwork came in the way. Now i'm back with more pictures than ever!
I've taken apart my prodigy and removed all the hardware, to get ready for modding.
BIG ASS pictures coming up!
Got some rivets on the back that need to go
Uuuh a treasure chest!
And here an old m-atx mobo that i use as a template
I screwed up  :( made a dent in the soft touch handles, but i can live with it.
I'll be making a new one of this!
Gotta love shaky footage..
Main Rig
Phone
https://linustechtips.com/topic/55291-project-prodigod/#findComment-781260
