I got this problem, I didn't know since when but for sure it's annoying. What happened is everytime I opened YouTube and start playing some videos, correction A VIDEO, static sound would continuesly appearing in and out. I don't know what causes it, I have updated my web browser but I cannot really seem to find a way out. It only happens on youtube videos, movies, music on my pc is unaffected.
Edited by Annoyingnerds
DESKTOP PC :
  CPU :RYZEN 5 2600/ GPU :MSI Ventus OC GTX 1660 Ti/ RAM :Team Elite 2x8/ PSU :Corsair CX650M/ HDD :Toshiba 2TB/ SSD :Adata XPG M.2 SATA 265GB/ COOLER :Be Quite 2x140mm / MOBO :Asus TUF B450 Gaming
LAPTOP :
  CPU :i7-4710HQ/ GPU :GTX 860M/ RAM :8GB OEM/ HDD :1 TB
PERIPHERALS :
  MOUSE :LOGITECH G502/ HEADSET :HyperX Cloud Alpha/ KEYBOARD :Logitech G Pro
POSSIBLE PC BUILD :
  PC PART LINK
https://linustechtips.com/topic/552842-youtube-static-sound/
Install Flash Player and get a Firefox extension called  "HTML player disabler" or something like that.
BTW Wrong subforum, you had to post it in Troubleshooting. Some mods will probably move it.
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/552842-youtube-static-sound/#findComment-7290696
I'm using chrome
DESKTOP PC :
LAPTOP :
PERIPHERALS :
POSSIBLE PC BUILD :
  PC PART LINK
https://linustechtips.com/topic/552842-youtube-static-sound/#findComment-7290721
If it's just one video it's probably not your computer.
i like linux
https://linustechtips.com/topic/552842-youtube-static-sound/#findComment-7290723
what I meant to say it's after one video and it continued to the other video I played
DESKTOP PC :
LAPTOP :
PERIPHERALS :
POSSIBLE PC BUILD :
  PC PART LINK
https://linustechtips.com/topic/552842-youtube-static-sound/#findComment-7290727
It may be wifi signals messing with your speakers, videos can cause this as well as downloading anything. Try downloading something and see if that sound occurs when that is going on too. Or it may be something else, but I am currently going through the above mentioned so I thought that that may help.
https://linustechtips.com/topic/552842-youtube-static-sound/#findComment-7290730
