Ghetto Heatsink Fan
bamchi
nah
you need some duct tape to hold the fan on properly
then you'll get over 9000 fps
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
Not sure why you need push/pull?
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
It would work, i don't know how long the tie will hang on for with all the vibrations though.
I'm interested to see if it makes a difference!!
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
As a wise, salty Army SSG once told me: "If it's stupid and works, it ain't stupid."
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
Hey, what cpu is it
if it is an i3-i5 yes it will work
i7-to any fx chips no
1 hour ago, TheCODclown25 said:
Hey, what cpu is it
It's an AMD A10 7850K :P
Haven't tested it yet but yeah.
That's the best point i've seen in........ages....
19 hours ago, bamchi said:
Is this Ghetto enough?
will this work?
My question is who is that smexy lady as your avatar.
Also yes it will work. Just make sure the other fan stays on :P
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
Ok how come this guy gets props for having ghetto stuff but i get kids saying im poor
That is a thing of beauty. I can hear the "Sanford and Son" theme song playing in the background.
Aerocool DS are the best fans you've never tried.
Dude its only a 3 dollar fan and some elastic fabric or "Garter" in the phil.
When you're so broke but you have household items.
Ok it being only 3 dollars justifies my case even more
Let us see your outstanding case.
