HeyGuys
After the weekend the part for my custom loop will arrive. I've been watching videos on how to install GPU/CPU block and fill the loop etc, and I know how to do most of that stuff. But since it's my first time ever I'd like to hear tips/tricks from the people who are experienced! :D
Also 1 question: To clear the thermal paste from the chips, do I NEED to use isopropyl alcohol or can I use other things? (If yes, what other things can I use?)
Thanks!
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/551090-first-time-custom-loop-questions/
2 minutes ago, yannickverc said:
HeyGuys
Thanks!
It is best to use isopropyl alcohol as it is cheapest and works! :) Unless you get some thermal paste remover for free with some thermal paste (i did) I would stick with isopropyl alcohol
If you want a reply PLEASE QUOTE ME!
WE NEED CUSTOM MEMBER TITLES AGAIN!!!!!
Member title post link!
just watch all singularitycomputers videos, thats all the tips you ever need
and you can just use a damp cloth with water to remove the thermal paste
Oh really? lmfao nice.
Thank for the suggestion, will watch their videos!
I really wouldn't recommend this, if you happen to get water anywhere you may cause a short. Isopropyl dries nearly instantly, is cheap, and is non-conductive, just use that.
Problem is that I don't have it, and I have no idea where I can buy that stuff :/
Literally almost any store in the world. Isopropyl is just rubbing alcohol. Most gas station convenience stores will have it. Grocery stores/super markets. Pharmacies. Eye glass stores, the list goes on.
Ah nice. I don't know the name for it in my language so that's why I was wondering :)
DAMP NOT SOAKING
all you need it for the cloth to be slightly wet to wipe the paste off , it also dries in a few seconds
and of course wipe with a dry cloth afterwards to make sure there is nothing left behind
Make sure you take your time installing the blocks and make sure the screws all line up properly. You don't want to use force and damage the threads. People recommend isopropyl alcohol because it evaporates quickly and have a less likelihood to damage the components if it makes contact. You could also use Arctic silver's cleaning kits as well but are less available and more expensive.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
