PC partpicker says there wont be a problem so il go with that, looks like it would work
Builds:
https://linustechtips.com/topic/547357-will-it-all-work/#findComment-7233624
2 minutes ago, manikyath said:
looks good to me.
small piece of advice about the RM750: your pc wont pull enough wattage to have the fan kick in, so flip it fan side up to it can vent passively more efficiently.
 ok thanks!!! you think I should just get more power? if so what should I get?
https://linustechtips.com/topic/547357-will-it-all-work/#findComment-7233655
i'm saying that the power supply will have enough headroom to run fanless, so when building, take in mind it'll most likely never use its fan, and vent passively.
https://linustechtips.com/topic/547357-will-it-all-work/#findComment-7233671
