Need some cooling advice.
I'm in the stock cooling club.
I was wondering if anyone could show me to a popular program that will measure how hot my CPU is running, but if not I'm kind of just under the impression that my CPU is running a bit hot, but it's also been used for atleast a few years to the point where I just don't feel it should have to still be using stock fans.
I've never shopped for cooling before. I didn't even know water cooling was a thing until I found Linus' channel. But the thing is I'm clueless as to just how much a difference water cooling would make over air.
An air cooling upgrade would be the cheaper option and this air cooler for about 30 dollars for this one which looks a lot nicer than my stock one:
http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI/ref=sr_1_1?s=pc&ie=UTF8&qid=1455403927&sr=1-1&keywords=cpu+cooler
Water cooling seems to cost atleast double that at 60 dollars, but I need to know how much more a difference it will make if I'm to dump an extra 30 dollars into it.
http://www.amazon.com/Corsair-Hydro-Performance-Liquid-Cooler/dp/B00A0HZMGA/ref=sr_1_2?s=pc&ie=UTF8&qid=1455404109&sr=1-2&keywords=cpu+cooler
My Processor is an I5 3450. Never overclocked it, nor do I plan to. My system is open air if that makes a difference.
https://linustechtips.com/topic/547302-need-some-cooling-advice/
Just grab the CM 212 Hyper EVO since your CPU is locked. You won't need a fancy AIO one.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/547302-need-some-cooling-advice/#findComment-7233047
Hyper212 is the best performance for money cooler I can think of, if it will fit in your case(it's a bit tall) I would definitely pick one up.
my work in progress
i5 6600k  //  16gb g.skill ddr4 3000  //  evga gtx 980
custom water loop
https://linustechtips.com/topic/547302-need-some-cooling-advice/#findComment-7233070
Height is no problem for me. Looks to be the popular option so I will go with that. Thanks.
https://linustechtips.com/topic/547302-need-some-cooling-advice/#findComment-7233079
use hwmonitor or aida64 to measure temps
intel XTU also tells you
https://linustechtips.com/topic/547302-need-some-cooling-advice/#findComment-7233080
A good method of cooling is to simply blow onto your heatsink. That's what I do.
either way. The Hyper212 evo is a good and popular cooler
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/547302-need-some-cooling-advice/#findComment-7233106
Use software like HWMonitor, Msi Afterburner, CoreTemp, etc. to measure your temps.
The 3450 shouldn't have any issues with the stock cooler.
https://linustechtips.com/topic/547302-need-some-cooling-advice/#findComment-7234956
