So I own a rear exhaust 660ti and the temps are somewhat worrying.
I own this card for almost 2 years now these temps are a new thing.
And my cpu is AMD Athlon II x4 651 at 3 ghz
At the moment I have absolutly no fan in my case and it's sitting on a
carpet but it doesn't matter cuz it has the psu on top of the case...
And I have no idea what case is this 0 branding but it's cheap
In CSGO it was 75-85 degrees Celsius at 200 fps (cpu game)
In Battlefield 4 sits at 90 degrees on ultra/low at 60 fps which didn't happen before
In Msi Furmark something kombustor something it locks on 93 degrees
In Heaven Benchmarak 4.0 is stays on 88 degrees
And each one of these resulted in 70% fan speed which is not as quiet as I would like.
And these are some dangerous temperatures ain't they and my questions are:
What are the normal load temps for a rear exhaust 660ti?
How could I reduce the thermals diffrent ways than changing
out thermal paste, buying a new case and fans? (which ima do)
https://linustechtips.com/topic/547301-dangerous-temps/
remove all dust from your PC, heatsinks, fans, everywere then look at temps
Builds:
https://linustechtips.com/topic/547301-dangerous-temps/#findComment-7233072
4 minutes ago, Knaj said:
1: Get a front fan in the case.
2: Clean the dust.
6 minutes ago, App4that said:
First a foremost clean the dust from the entirety of your PC. Then revisit the issue.
ok, what about the normal 660ti temps?
https://linustechtips.com/topic/547301-dangerous-temps/#findComment-7233076
i dont know but im guessing around 30C or something
Builds:
https://linustechtips.com/topic/547301-dangerous-temps/#findComment-7233094
Well, with no case fans, you cant ask for much.
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/547301-dangerous-temps/#findComment-7233112
3 minutes ago, Sir_Chicken said:
I meant under load what temps you could expect
60-70C maby, never owned one but thats what it probably should do
Builds:
https://linustechtips.com/topic/547301-dangerous-temps/#findComment-7233120
If I deciphered your post correctly, you currently don't have any fans in the system? I'm not sure how you've maintained any kind of respectable temp for anything inside your case, but be that as it may I'd do what everyone else has said - clean that puppy out from top to bottom and throw some fans in there to move the air around. Under load it shouldn't get to no more than 80C. It'll start to throttle around 90C. But this is assuming good ventilation and proper care which obviously hasn't been going on. Clean it out dude.
https://linustechtips.com/topic/547301-dangerous-temps/#findComment-7233168
Currently my bad case has a single spot for a fan and the inside really isn't that dusted, it's not like I didn't do anything. But I'm gonna get a new case now because I have a lot of free time and maybe try cleaning the insides & changing out the thermal paste
https://linustechtips.com/topic/547301-dangerous-temps/#findComment-7233187
Don't forget fans, lol
https://linustechtips.com/topic/547301-dangerous-temps/#findComment-7233190
