Water cooling or air cooling
Solved by glitchmaster0001,
here's what i have to say about air/liquid cooling if your tight on a budget and you dont plan on doing to much overclocking then the hyper 212 evo is a good bang for buck cooler. if you got money to spend and you want your pc to look nice and you plan on some overclocking but dont want a $400 custom loop then a decent $80 or $100 AIO Liquid cooler will run you fine. personally for me i was very lucky to be able to buy a brand new Corsair h70 Core AIO Liquid Cooler for like $8 at WeirdStuffWarehouse.
