Minecraft client and server issues... plz send help
Solved by Enderman,
the server should not lag at all unless the tick is above 50ms
try running it with a batch file
"C:\Program Files\Java\jre1.8.0_73\bin\java" -server -XX:+UseConcMarkSweepGC -XX:+UseParNewGC -XX:+CMSIncrementalPacing -XX:ParallelGCThreads=4 -XX:+AggressiveOpts -Xmx8G -Xms2G -jar "C:\serverlocationgoeshere\minecraft_server.1.8.9.jar" nogui
make sure the name of the java file and server file in the batch file match the actual file name and location
you can adjust the ram too if you dont have 8GB
