3 minutes ago, DominicNikon said:
so what advantages does it supply?
Not having to mess with adaptive voltage settings. OC, set it, forget it.
I run all my systems 24/7 OC'd. The ramp down in wattage due to clockspeed alone is minuscule (~10w for a heavy OC). With average electricity prices at $0.16/kWh in the U.S. it's not going to make much difference. You're only going to save a considerable amount of money if you lower your OC+voltage and run your system at full load 24/7.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
should i use my i5 with out turbo boost and stuff and just run 4.5ghz at 1.345V 24/7?
Well, yeah.
You should always be donating your idle compute power anyway, so you might as well give it OCed performance.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
That's up to you. There is no real benefit though. I run mine oc'd to 4.4 with turbo and speed stepping enabled as well as adaptive voltage. But if you don't care that your cpu is running full pin when it doesn't need to, then be my guest.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
Completely a personal decision if you want to take the time to dial in adaptive. I run synth tests often enough to the point that it's more of a PIA to constantly switch back and forth, and I don't care about power consumption on my main machine.
1.345 for 4.5? That's rough
Yeah I any lower voltage and it crashes
