Quietest fans?
Solved by Enderman,
3 minutes ago, verydogesuchwow said:Black frame is ok, not preferred, but I wouldn't say no to a good one with a black frame
i would go with the eloop instead of the bitfenix one, its made with much more premium materials and is quieter too
they have a 800rpm version that is only 8dba
the 1300rpm version is 17dba
http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-eloop-series/120x120x25mm.php
the 1500rpm PWM version (which i have 3 of) is 21ba but it can be run down to about 10% speed which makes it virtually silent
obviously at 10% performance isnt that great though ![]()
