pc 950 EURO gaming/streaming system
Solved by MarkoCroatiaMC,
1 hour ago, BlueWaterGaming said:do you guys have any suggestions?
http://de.pcpartpicker.com/p/jdrqcf <<< without exta stuff
http://de.pcpartpicker.com/p/R47h4D <<< includes everything (alreadey have headphones)
http://www.newegg.com/Product/Product.aspx?Item=9SIA6ZP3N68485 <<< the case
its the best i could find after 20 hours of searching around
why get an unlocked cpu if your mobo isn't meant 4 ocing, it's not a z170 chipset mobo + http://de.pcpartpicker.com/p/pFFdpg (u can remove Hyper 212 if it's over your budget. probably even won't make any difference)
