I have no idea whats going on
4 minutes ago, Duchess said:Also what size is best? I at some point want 2 GPUs if that matters. And whats the pricebreak where youre just wasting money?
It's hard to call something a waste, as worth is subjective. Some people will scold others when they spend $400 on a motherboard, but that person could also need PEX8747 for quad SLI.
For most budget SLI boards. $100-$200 is the price range. http://pcpartpicker.com/parts/motherboard/#l=2&sort=a8&page=1&s=24,30
However, when you click the 3-way SLI button, you notice a change. http://pcpartpicker.com/parts/motherboard/#l=3,4&sort=a8&page=1&s=24,30
All of a sudden, the cheapest board capable of 3way SLI is $200. However, the performance gained for being able to leverage that extra card is worth it to some people.
For size, it depends on what you want. However, if you want to use two GPU's, do not go any smaller than Micro-ATX. Mini-ITX will not be able to leverage SLI or Crossfire without a dual slot riser card, and a motherboard with a BIOS to support it (ASRock does with my BIOS at least).
As others correctly stated, there are also differences with chipsets that directly impact performance. H series boards do not have native support overclocking. The Z chipsets however, can overclock both CPU and memory, resulting in more performance:dollar if done correctly.
I would take the advice of others listed in this thread. Try to go with a standard ATX board, preferably Z series if going Intel, and invest in the best board you are willingly able to afford. If price is a factor to you, then make a list of things that you absolutely want, and see if you can fit them into the budget. You mentioned dual graphics, is that AMD or Nvidia? AMD can run in crossfire on H series boards, so you can technically save money by going that route (albeit you lose the overclocking mentioned previously). If you want dual graphics under Nvidia, then a Z/X series board is pretty much your only option. At that point, buy the cheapest board that offers what you are looking for on your list of features, and enjoy yourself. Since you don't exactly know what most of the ports do. I highly suggest using pcpartpicker with the compatibility filter turned on. It will warn you if your parts list has any issues.
Good luck.
