For about two weeks now I have been having weird internet problems. I say that they are weird because I am getting descent download and upload speeds, but I still have to reload pages multiple times to get them to work.  my current ISP is Comcast and my family is paying for around 75mb download and At the moment I am getting:
ping: 18ms
down: 11.28
up: 12.20
The Speeds are not really my problem although its not what we are paying for (I think this is just Comcast being back and or my Ethernet over power line being bad). My real problem is that things just plain wont load half the time. In the case of YouTube the videos will load sometimes and other times they will just load the first couple of seconds. I have tried testing it on my phone as well as on my laptop and desktop and i am still having the problem. which mean its not the WiFi and its not my Ethernet over power line. My current idea is that my step dad has the modem/router plugged into a daisy chain of coax cables and splitters.
Could this be my problem or is it something else?
https://linustechtips.com/topic/543973-wierd-internet-problems/
sounds kinda like high pacadge loss meaning you recive an answer from the server but its not relevant data/ corupted data. your network sounds like a mess so im guessing the data is getting "lost" there, its always best to have a direct conection to your router but a couple of switches should be fine, what your describing sounds like a nightmare tho
Builds:
https://linustechtips.com/topic/543973-wierd-internet-problems/#findComment-7196783
check your package loss
https://linustechtips.com/topic/543973-wierd-internet-problems/#findComment-7196804
1 minute ago, Potato_Slayer said:
it is a nightmare, a big problem of this is that i have very little control over the internet because of my step dad, so its hard for me to test things in more detail. im not even aloud to run an either net cable out the window to my room
well check how much package loss you are getting and reply here because thats probably it, not sure what you can do but if you could get acces to the router settings you might be able to promote your computers priority, not sure if you can do that but worth a try :)
Builds:
https://linustechtips.com/topic/543973-wierd-internet-problems/#findComment-7196852
well i had to use internet explorer because chrome doesn't support java anymore but i did it. pingtest.net is saying i have 0% packet loss. i also made sure i was still having problems with YouTube and such.(which i still am)
https://linustechtips.com/topic/543973-wierd-internet-problems/#findComment-7196943
Try pinging a PC in your network from another PC in your network. IE Windows Key + R > CMD > Ping -n 50 192.168.1.2 while on 192.168.1.3 or what ever your IP scheme is. If you find the Powerline is the problem, check the coaxial you are running it over. What model power line are you using?
Also try setting your DNS to static. ISP DNS is known to be flakey. If the DNS request is delayed, that might explain why throughput is good, but pages delay. See here for GoogleDNS or pick your own. Also make sure you don't have DNS relay or cache enabled.
Last, check the signal levels of the modem/gateway. Usually you can access it by 192.168.100.1 or 192.168.0.1 depending on the model. What model router/gateway do you have?
https://linustechtips.com/topic/543973-wierd-internet-problems/#findComment-7197968
Good advice overall, but methinks you got confused around this part: "If you find the Powerline is the problem, check the coaxial you are running it over."
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/543973-wierd-internet-problems/#findComment-7200102
well then i have no idea whats wrong with your conection
Builds:
https://linustechtips.com/topic/543973-wierd-internet-problems/#findComment-7201080
