F@H not respecting CPU settings at all
Well you got multiple issues going on from what I could see....
1. Idle light: That sounds like the software is bugged.
The way it should work is that when the computer is idle, 1/2 the core/thread available on the cpu should only be used when running on Multiple cores and the gpu is running.
https://fah-web.stanford.edu/projects/FAHClient/wiki/ClientPerformanceLevels
The moment the computer isn't idle, everything should stop running.
Although my solution beyond reinstalling the software is to manually limit the number of threads used.
(ignore the red boxes, it's an image from the overclock.net V7 guide point out a different subject)
That SMP slot you see (now labeled just as "CPU"), you can change that "-1" to a different number ( -1 = using all cores/threads).
So if you only want to run on 1, 2, 3, ect threads, you can tell it to run on that many.
2. Unless you told the client to run on 1 thread only, the cpu % slider (10% in your case) doesn't work when running on multiple threads. So dont worry about that setting unless you plan to run on 1 thread.
3. At stock settings and clocks last i checked, the HSF shouldn't be allowing the 2600k to get that hot while folding. (Mid 70c to low 80C should be it last i knew)
http://hardforum.com/showthread.php?t=1580558
I would recommend checking to see if all the push-pins are in to be sure the HSF is making good contact with the cpu (seen it a few times where you "think" those pins are pushed all the way and there not).
If that isn't it, then new thermal compound might be in order.
Beyond that, besides the underclocking you've already done, the only 2 things that can reduce temps without buying a new cooler is
1: to reduce voltages. You could possibly left it at stock clocks and reduced the voltage. On my Penitum 4 2.8GHz HT in the old days (478 socket), i was able to go from 80c to 75c when folding (And I wasn't being aggressive on the voltage reduction. So i could of done more). All without changing clocks.
While I haven't done it with my Core i7 920, I do know of other guys with the same cpu as your have reduced voltage and seen temp drops with no stability problems.
2. turn off hyper threading. It's been know that you can drop the temp a little bit by turning it off. Some users see up to 10c.
Hope this all helps. If there anything else you need help with, just let me know.
Edit: For got to mention, if you do turn off HT, you'll loose some F@H performance.
