The luxe is prettier IMHO.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/541760-case-opinions/#findComment-7172042
1 minute ago, DaltonM said:
These are very different cases.
I would say the Thermaltake because it's just so badass, but neither of those cases are ones I would go with.
If you have a sick water cooling loop, definitely the thermaltake.
lol what about if I don't have a water cooling loop, still worth it?
https://linustechtips.com/topic/541760-case-opinions/#findComment-7172051
If you have sexy hardware you want to show off. Do you take your PC places? Do you have a nice room to display it in?
Don't get a sexy clear, open air case if you're gonna stick under your messy desk :)
https://linustechtips.com/topic/541760-case-opinions/#findComment-7172058
I think my gpu cooler looks pretty sexy, I just would have to find a good place for it...
https://linustechtips.com/topic/541760-case-opinions/#findComment-7172067
neither....
https://linustechtips.com/topic/541760-case-opinions/#findComment-7172088
1 minute ago, N64CUBE said:
Why's that?
the enthoo cases have a really thin vertical window which barely lets you see half of whats inside the case
the design is also not my style, with rounded corners and front that sticks out
the thermaltake case is made by thermaltake, so you can expect the crappiest materials from china
if i wanted an open air case like that i would buy something from inwin or lian li, who actually use high quality steel and aluminum, and tempered glass, not cheap chinese alloys
but i wouldnt want an open air case because of the amount of dirt/dust that could get in
https://linustechtips.com/topic/541760-case-opinions/#findComment-7172107
If that's real glass on the thermaltake, then the thermaltake is WAAAAAAAAAAAAAAAAYYYYYYYYYYY better.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/541760-case-opinions/#findComment-7172117
I'm also not a fan of the look of phanteks cases.  I like the clean design of cases like the fractal define series and the nzxt s340.
https://linustechtips.com/topic/541760-case-opinions/#findComment-7172131
