Hey ppl
i gave my friend my old pc. now we bought a new graphiccard for it and i've tried to install it, the graphiccard now doesn't work or show any sign of life. the mainboard got 2 pci lanes, it doesnt work in other one either.
mainboard: asrock z77 extreme 6
graphiccard: gigabyte 970 g1
PSU: Club 3D 1000 Watt
CPU: i5 3570K (cooled by corsair h80i)
Ram: Corsair platinum 2x 8 gb 2133mhz
do you have any ideas'
https://linustechtips.com/topic/541220-problem-with-gtx-970-g1/
Just now, stephan_kirchhoff said:
1000W should be enough i think ;)
What brand of psu?
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/541220-problem-with-gtx-970-g1/#findComment-7166444
1 minute ago, App4that said:
Only way to know for sure is try another known working graphics card, or use the iGPU.
the pc works and he allready uses its just the gpu doesnt work, i took the gpu with me and try to put it in my pc and see if it works
https://linustechtips.com/topic/541220-problem-with-gtx-970-g1/#findComment-7166577
Since when is the 970 G1 bad?
It's been one of the most popular 970's since release since it's one of the best overclocking 970's.
Unless something happened recently with their quality control, I don't know what everyone is talking about.
There wasn't a big news story or discovery recently that I've heard of or anything
https://linustechtips.com/topic/541220-problem-with-gtx-970-g1/#findComment-7166656
11 minutes ago, App4that said:
Probably the graphics card then. RMA it. And next time don't buy Gigabyte.
my rig is full of gigabyte stuff, i actually liked them and had no problem, thats why i recommened them, but i will try to get another one at my dealer
https://linustechtips.com/topic/541220-problem-with-gtx-970-g1/#findComment-7166686
3 minutes ago, Hunched said:
True, but you and others were bashing their products, which are usually some of the best, at least on the Nvidia side.
No, not the best. Popular yes, but far from the best. EVGA is the best for Nvidia. The FTW+ is a better graphics card than the G1. Gigabyte is banking on no one making sure their products are still good.
If anyone asks you never saw me.
https://linustechtips.com/topic/541220-problem-with-gtx-970-g1/#findComment-7167389
